Hi Ciara,
I also have a similar workflow that you may find useful. This is the python script I use. It spatial joins your parcels layer to the facilities layer and will output a new layer with just the APN and the facility ID with a single APN and a list of all the facility IDs. I run this same function to against multiple layers and then join them all together using the APN field so I can have a master parcel layer that has the APN, a list of addresses on the parcel, a list of facility IDs on the parcel, any related tract map information on the parcel, treeIDs on the parcel, etc.
You would have to update line 3 so that the value after apnField is the actual name of your APN field and value after apn_Layer is the name of your parcel layer. then in line 55, you update the values of your actual facility layer, the name of the facility ID field, the name you want the facility ID field to have in your new layer, the path of the new layer, and then set the length of the field. Some of the layers I join to my parcel layer have a lot of intersecting records, so the field length can vary. Hope this helps!
import arcpy
def comma_join(inputLayer, inputField, outputLayer, fieldName, fieldLength, apnField="APN_SPACE", apnLayer = "Your_PARCEL_Layer", mergeRule="Join"):
Performs a spatial join and keeps a target field with values joined by commas.
Parameters:
- inputLayer: Layer on which the spatial join is performed.
- inputField: Field in the input layer whose values need to be comma joined.
- outputLayer: The resulting layer after spatial join.
- fieldName: The name of the new field where the joined values will be stored.
- fieldLength: The length of the new field.
- apnField: Name of the APN field. Default is "APN_SPACE".
- apnLayer: Name of your Parcel layer or layer with APN vales. Set the default here if you want to use this code on multiple layers
- mergeRule: Rule for merging the fields. Default is "Join".
#Names of fields you want in your output layer
keepers = [apnField, inputField]
#Maps fields from APN layer and target layer to new layer
fieldmappings = arcpy.FieldMappings()
fieldmappings.addTable(inputLayer)
fieldmappings.addTable(apnLayer)
#Remove all non-APN values
for field in fieldmappings.fields:
if field.name not in keepers:
if 'APN' in field.name:
pass
else:
fieldmappings.removeFieldMap(
fieldmappings.findFieldMapIndex(field.name))
fNames = arcpy.ListFields(inputLayer)
for f in fNames:
if f.name == inputField:
fidx = fieldmappings.findFieldMapIndex(f.name)
fmap = fieldmappings.getFieldMap(fidx)
fmap.mergeRule = mergeRule
fmap.joinDelimiter = ","
theField = fmap.outputField
theField.length = fieldLength
theField.name = fieldName
theField.aliasName = fieldName
fmap.outputField = theField
fieldmappings.replaceFieldMap(fidx, fmap)
#The spatial join
arcpy.SpatialJoin_analysis(apnLlayer, inputLayer, outputLayer, "", "",
fieldmappings, "", "", "")
comma_join(*FACILITY_LAYER*,*FACILITY_ID_FIELD*,*NEW JOINED FEATURE PATH*, *NEW_FACILITY_ID_FIELD_NAME*,*SET A LENGTH OF THE FIELD*)
