marc alfsen, did you ever resolve this issue? And if so, what did you do to get it resolved?
I am now in a situation where ArcGIS Pro is totally unusable on my home laptop (it runs fine on my desktop). All maps and layouts are permanently stuck on the pause display and Pro reporting the "hardware graphics change" warning. Closing and re-opening the project and maps / layouts doesn't help, clicking on the "Pause" icon in the lower right of the display does nothing to resolve the issue. Upgrading to the latest NVidia driver neither helps. It has an GTX 1050 / 4GB laptop videocard.
I was already in a situation where I couldn't run Pro properly on the laptop itself (screen stuck), but could run it on an external screen connected via HDMI (screen normally usable). However, now, after upgrading to Windows 10 v2004, ArcGIS Pro on the external screen is stuck as well on a paused display.
I already contacted ESRI support here in the Netherlands before about the issue (which wasn't resolved then, and since I had other things to do, I left it at that at some point since the laptop could still be used on the external screen and I wasn't in a dire need for mobility with this home laptop).
All other software, including e.g. ArcGIS Earth, runs fine on the laptop. It is just Pro getting stuck with the map display.
Seems I will need to re-open this issue with ESRI...
