Hi, I had to go ask a colleague, but you select all the features you want to rotate, select the Rotate tool, move the rotation circle center point to where you need (control key, drag it and snap it somewhere, then spin it round using the green circle edge as a handle. There is an option to enter an angle (which is relative to the map's rotation). Looks like someone beat me to the workflow below!
