My dataset has numerous fields and it's joining with a table with similarly numerous fields so I wanted to reduce the number of scrolling I'd have to do. I had the Fields View of my feature layer and specified the fields I want to keep visible. This didn't seem to trigger ArcGIS Pro to do anything to the attribute table itself when I went to view it. When I closed the Fields View, it told me:
Unsaved Changes Found
Are you sure you want to close this pane? All unsaved edits to this workspace will be lost...
OK | Cancel
I clicked Cancel and looked for ways to save this state. Ctrl+S, in the Ribbon, etc... and tried closing the pane again - still the same message.
There doesn't seem to be way from the attributes table view to turn off fields either so I'm stuck.
Is there a step I'm missing to transfer the field visibility state over to the attribute table view?
Thanks.
