At the top pane, go to "Insert"
Then click "Add Folder"
Then navigate to the location you want to keep the file and select that, or make a new folder, and chose that folder.
Then right click the blank area of the folder area, select "New" from the popup, then you can choose shapefile or geodatabase, etc. I hope this helps.
