Scott - there isn't an idea as far as I can tell. This is being tracked as [BUG-000109755: The printer margins are not displayed in the ArcGIS Pro layout.]
If you need to be attached to that issue, you can call technical support. Otherwise, if you just want to track it, you can go to support.esri.com, search for the bug and then subscribe.
