Intersect Tool Pro 2.6 XY Tolerance is gone from main window
525
08-12-2020 04:18 PM
AlexShubra
What happened to the Intersect tools XY tolerance field that would allow you to buffer the inputs? Is this the same one that is within the Environments window now?
DanPatterson
From
Intersect (Analysis)—ArcGIS Pro | Documentation
Intersect honors all the properties that can be set in the Environments tab
Environments
From
It is recommended not to change the property if you don't need to but ensure that the spatial reference of the data is set up properly
... sort of retired...
