Is ArcGIS Pro compatible with Server 10.2?
2405
6
08-04-2015 11:12 AM
SaskiaCohick
New Contributor II
    Is ArcGIS Pro compatible with Server 10.2?  I would like to load Pro on my computer but need for it to be able to connect with Server 10.2.
DanPatterson_Retired
SaskiaCohick
New Contributor II
Unfortunately that does not detail which versions of Server it requires, or if there is no issue.
MervynLotter
Occasional Contributor III
Hi Saskia
It is my understanding that Pro can only publish to Portal, federated to a
server, but not directly to ArcGIS for server.
SaskiaCohick
New Contributor II
Thanks, however I am not looking to publish to a server.  I want to be able to consume the data on an existing ArcGIS for server instance without upsetting the entire 'apple cart' for my one ArcGIS Pro installation.  I want to give it a spin before making any full scale determinations of how appropriate it would be for everyone in our organization.  My local hardware and software are more than adequate, but I need to be able to access the data currently on our organizations servers.  That will make it not worth my while to just see how we would like it.
CarlByers
New Contributor II
My understanding is that Pro can consume resources from any recent version of ArcGIS - Desktop or Server.
But why guess....
click on this...
Supported platforms
  Check your computer's ability to run ArcGIS Pro
In the link I provided...
ArcGIS Pro system requirements—ArcGIS Pro | ArcGIS for Desktop
Take the guess work out...try it...it might work...if not, it will tell you why
