In ArcMap, it is possible to select multiple shared polygon edges with the Topology Edit Tool by holding SHIFT and clicking multiple edges. This is especially useful when editing the edge of a polygon that shared edges with two other polygons. In ArcGIS Pro, it only seems possible to select a single shared edge before using the Reshape tool (or other tools, e.g. Vertices). I tried holding SHIFT, and it does not work the same as in ArcMap. Is there a different method for selecting multiple topology edges while editing?
Additionally, is it possible to select a topology edge and have it stay selected after using an editing tool? If I want to reshape the edge and then reshape another part of the same edge, currently I have to reselect the edge each time I want to reshape it, but maybe there is a way to keep it selected between editing actions. Any help with that? Thanks.
