Is there arcade global variable for map series titles
489
08-23-2019 11:21 AM
jasongraham
I am attemting to change symbology based on map series title using arcade in pro.  However, I dont see any globals related to layout.  Am I dreaming too big here?
for example, I have four pages in series, the spatial extent is identical. I have similar columns
when the page is changed I want to show only that data.
I thhik in the symbology for that layer...
In the "field" I can add arcade code to match the title to the column.  I just dont see a way to reference layout items.
I appreciate any help.
for example
Decode( $map.series
  '1996-2000','$feature.F_Effort_prop_user_year_bin___96_00',
  '2001-2005','$feature.F_Effort_prop_user_year_bin___01_05',
  '2006-2010','$feature.F_Effort_prop_user_year_bin___06_10',
  '2011-2016','$feature.F_Effort_prop_user_year_bin___11_16',
'none')
where map series title is 1996-2000 and the column is named F_Effort_prop_user_year_bin___96_00.
however "$map.series"  is not an actuall thing, is there a reference I can use here?
Tags (3)
