Map service symbology as esriSMS types from ArcGIS Pro
150
04-17-2024 01:52 AM
MarianHaluska
New Contributor II
Hi all,
I'm triing to publish a map service (with point layer) where symbology (Drawing info) would be kept as esriSMS type, currently I'm using ArcGIS Pro 3.2.2 and ArcGIS Server 11.2. I publised a test map service with multiple layers and only 2 types of symbology were kept as esriSMS: circle and square. All other (cross, diamond and triangle) are set to type "image/png". According to ESRI docs the other symbol types sould also support esriSMS type. Am I missing something or does this not aply in this case. When symbolising the layers I used pre-defined shapes from apperance section of symbology settings (picture 1) . The only added settings were halo and rotation of the symbol. I 'm also sending a zip-ed .json file with information about tested layers.
Thank you wery much in advance
