I have a script that worked perfectly last week...before I upgraded from ArcGIS Pro 2.9.5 to 3.2 (see below script).
The script is something that I recreated using help from this post (thank you @jcarlson). The script is run within the python window in Pro.
When I re-ran this script this week, after updating to Pro 3.2, the script no longer works. I was able to test it on a workstation that was still on 2.9.5, and it works! So that is pretty clear to me that something has changed from the python/panda libraries between 2.9.5 and 3.2.
The error I am getting happens on the last line of the script when I try to write the dataframe to a table. Yes, I know the table does not have any geometry, but this worked in the past and created a fgdb table perfectly. The error I get is: "TypeError: 'field_names' must be string or non empty list or tuple of strings"
I am a self-proclaimed hack at python/pandas, so any help is greatly appreciated to get this up and running again.
@jcarlson
@DanPatterson_Retired
import arcpy
arcpy.env.workspace = "N:\ArcShared\Planning\CompPlanUpdate_2025\Data\BellinghamProfile\BhamDataBook_2022.gdb"
arcpy.env.overwriteOutput = True
# Import modules
from arcgis import GIS
import pandas as pd
import requests
import json
#TOTAL POPULATION, SEX, AGE & RACE data for Bellingham City
# Submit request to API
response = requests.get('https://api.census.gov/data/2022/acs/acs5/profile?get=NAME,DP05_0001E,DP05_0002E,DP05_0003E,DP05_0005E,DP05_0006E,DP05_0007E,DP05_0008E,DP05_0009E,DP05_0010E,DP05_0011E,DP05_0012E,DP05_0013E,DP05_0014E,DP05_0015E,DP05_0016E,DP05_0017E,DP05_0018E,DP05_0073E,DP05_0079E,DP05_0080E,DP05_0081E,DP05_0082E,DP05_0083E,DP05_0084E,DP05_0085E,DP05_0019E,DP05_0024E&for=place:05280&in=state:53')
# Read response as JSON into dataframe
# First row is column names, skipped for data import
df = pd.DataFrame(response.json()[1:])
# Apply column names from first row
cols = response.json()[0]
column_dict = {}
for c in cols:
column_dict.update({cols.index(c):c})
df.rename(columns=column_dict, inplace=True)
df = df.astype({"NAME": str, "DP05_0001E": int, "DP05_0002E": int, "DP05_0003E": int, "DP05_0005E": int, "DP05_0006E": int, "DP05_0007E": int, "DP05_0008E": int, "DP05_0009E": int, "DP05_0010E": int, "DP05_0011E": int, "DP05_0012E": int, "DP05_0013E": int, "DP05_0014E": int, "DP05_0015E": int, "DP05_0016E": int, "DP05_0017E": int, "DP05_0018E": float,"DP05_0073E": int,"DP05_0079E": int,"DP05_0080E": int,"DP05_0081E": int,"DP05_0082E": int,"DP05_0083E": int,"DP05_0084E": int,"DP05_0085E": int,"DP05_0019E":int,"DP05_0024E":int})
# Export to layer
processed_table = df.spatial.to_table('DP05_Pop_Age_Sex_Race')
