Real surface area using a Raster Calculator in ArcGIS Pro
589
08-08-2023 03:17 PM
jahillganvar
I have a slope dataset. I have to count its real surface area using the following equation:
The count of the cells is 5839737. I tried to input the raster set and the count of cells in the equation but the calculator fails every time.
5839737 / Cos (["Reclass10"]) * 3.1415 /180
I input the above algebra expression which is wrong.
What can I do to correct the algebra expression?
DanPatterson
other than the numbers, did you type anything else, rather than selecting from what is provided?
the [ ] brackets don't look correct since Cos isn't for a list, but a raster
... sort of retired...
jahillganvar
kinda very late but removing the [] worked! thank you so much
DanPatterson
Glad it worked out.  It is the small things usually.
