Replace polygon but keep rest of attributes
1955
5
08-03-2016 08:53 AM
HectorBorro1
I have a layer with polygons and its identifier (attribute table is 3 fields: FID, polygon and Place_ID) I need to replace this polygon with the one in another layer (attribute table has 20 fields).
A tool that comes to mind is Append​​, but it will add a new row, which I dont want as the rest of the attribures will be lost.
Any ideas on how to replace these geometies? They are only 5 of them...
JayantaPoddar
Maybe you could start with Attribute Transfer Mapping to transfer the attribute to the new polygons.
http://desktop.arcgis.com/en/arcmap/10.3/manage-data/editing-existing-features/transferring-attribut...
Then you could go for Append or Update whichever is preferable.
Think Location
DanPatterson_Retired
HectorBorro1
mhh sounds like a good tool to use, thanks!
It seems its for lines, but I'll see if it works for polygons...
You are right... mea culpa
HectorBorro1
Thanks, I went first by manually deleting the rows, then appending the needed polygons and merging.
thanks all
