I have a layer with polygons and its identifier (attribute table is 3 fields: FID, polygon and Place_ID) I need to replace this polygon with the one in another layer (attribute table has 20 fields).
A tool that comes to mind is Append, but it will add a new row, which I dont want as the rest of the attribures will be lost.
Any ideas on how to replace these geometies? They are only 5 of them...
Maybe you could start with Attribute Transfer Mapping to transfer the attribute to the new polygons.
Then you could go for Append or Update whichever is preferable.
In Pro it would be Transfer Attributes—Help | ArcGIS for Desktop
mhh sounds like a good tool to use, thanks!
It seems its for lines, but I'll see if it works for polygons...
You are right... mea culpa
Thanks, I went first by manually deleting the rows, then appending the needed polygons and merging.
thanks all
