Reverse Geocoding Tool in ArcGIS Pro
6380
22
05-13-2015 09:05 AM
JeffWard
Occasional Contributor III
Is there such a thing in ArcGIS Pro as a reverse geocoding tool like the Address Inspector on the geocoding toolbar in ArcMap?  My searches haven't found one.
Jeff
Jeff Ward
Summit County, Utah
JeffWard
Okay,  I'll give tech support a call on Monday.
Thanks for your help.
Jeff Ward
Summit County, Utah
JeffWard
So it turns out the locators I had in ArcGIS Online were causing the problem with Pro.  Those locators were created with 10.2 and are hosted on Server 10.2.  Not sure if that is the issue, but I'm going to try creating new locators with 10.3.
Jeff Ward
Summit County, Utah
SimonJackson
In ArcMap, I was able to use the address inspector and hold the mouse down and hover over the map and get instant results returned (from a local locator).  I like the UX of the right click the map and 'whats here' but I would also really like to be able to have that same instant feedback.  Perhaps an address inspector could be an additional tool?
Example in ArcMap
