Rotate Data Frame or Data Frame Toolbar in ArcPro
4095
6
06-16-2017 07:11 AM
MatthewDuffy
Occasional Contributor II
I'm not sure if this is even available as it used to be in ArcMap.  I cannot tell one way or another within the allotted fifteen minutes of self-help, so I'm turning to our ever present trusted community.
I'm looking to rotate the map in ArcPro (Sorry, ArcGIS Pro:) and in ArcMap you can do this with the data frame tools.  I'm beginning to wonder if this is only available in ArcPro's 3D viewing mode or something, but haven't I looked yet.
I'd be grateful for any input on this, thanks much in advance and Happy Friday !
Tags (1)
3 Solutions
TimOrmsby
Hi Matthew, try this:
In the Contents pane, right-click the map name and click Properties. In the Map Properties dialog box, on the General tab, there's a Rotation setting. Pick or type the value you want. Click OK.
TimOrmsby
With release of ArcGIS Pro 2.0, there is now an on-screen control available for rotating maps. See The on-screen navigator for information and short video. MatthewDuffy
JohnTownsend
New Contributor III
You can also use the keyboard shortcut.  When in map view or an activated layout view, just hold down "v" key and you can rotate with your mouse.  Works in 3D or 2D and has become my favorite way to accomplish this.
Keyboard Shortcuts for Navigation
TimOrmsby
MatthewDuffy
That's it Tim, thank you.  Although it is not as sexy as the old click-and-hold tool function that can interactively rotate the map, it is just what I was looking for, thank you.
Robert_LeClair
Esri Notable Contributor
Or if you want just the Layout to rotate, then go the Layout Properties and you'll see a Rotate there as well.
MatthewDuffy
Thank you Robert, I will use this too
TimOrmsby
JohnTownsend
New Contributor III
