ArcGIS Pro 1.4
DB: Oracle 11g
Run Select Layer by Attribute on a Date Field ( is NOT NULL or is NULL) even successfully validating. Error ,
ERROR 000358: Invalid expression
Failed to execute (SelectLayerByAttribute).
selectlayerbyattribute
Sorry, cant delete this post. pls ignore this as i tried the same in ArcMap and it throws some Oracle error. The problem is this data is not ours. we can not work on it. a copy of this in our own database is fine both for ArcPro and Arcmap.
