I was able to accomplish setting the Time Zone name (i.e., the 'dateFieldsTimezoneID' property) using the script below. I also set the 'dateFieldsRespectsDayLightSavingsTime' property to True at the same time. This script iterates through all map services and makes the adjustments, but you could adapt this for publishing as well.
import requests, urllib, ssl, json, arcpy, sys
context = ssl._create_unverified_context()
baseURL = "https://<server_name>:6443/arcgis"
userName = "admin"
passWord = "password"
timeZone = "Central Standard Time"
parameters = urllib.parse.urlencode({'username' : userName,
'password' : passWord,
'client' : 'requestip',
'expiration': 60,
'f' : 'json'}).encode("utf-8")
response = urllib.request.urlopen(baseURL + '/admin/generateToken?',parameters, context=context).read()
jsonResponse = json.loads(response)
token = jsonResponse['token']
params = {'f': 'json', 'token': token}
req = urllib.request.Request(baseURL + '/admin/services?f=pjson', urllib.parse.urlencode(params).encode("utf-8"))
response = urllib.request.urlopen(req, context=context)
data = json.load(response)
for d in data['foldersDetail']:
folderName = d['folderName']
if folderName != 'System' and folderName != 'Utilities':
req = urllib.request.Request(baseURL + '/admin/services/' + folderName + '?f=pjson', urllib.parse.urlencode(params).encode("utf-8"))
for i in data['services']:
serviceName = i['serviceName']
arcpy.AddMessage("Modifying " + folderName + "/" + serviceName + "...")
req = urllib.request.Request(baseURL + '/admin/services/' + i['folderName'] + '/' + serviceName + '.MapServer?f=pjson', urllib.parse.urlencode(params).encode("utf-8"))
try:
dateFieldsTimezoneID = data['properties']['dateFieldsTimezoneID']
except:
dateFieldsTimezoneID = ""
data["properties"]["dateFieldsTimezoneID"] = timeZone
data["properties"]["dateFieldsRespectsDayLightSavingTime"] = "true"
updatedSvcJson = json.dumps(data)
editSvcURL = baseURL + '/admin/services/' + i['folderName'] + '/' + serviceName + '.MapServer/edit'
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
params = urllib.parse.urlencode({'token':token, 'f': 'json', 'service': updatedSvcJson})
r = requests.post(editSvcURL, params, headers = headers, verify = False)
if i['type'] == 'MapServer':
arcpy.AddMessage("Modifying " + "root/" + serviceName + "...")
req = urllib.request.Request(baseURL + '/admin/services/' + serviceName + '.MapServer?f=pjson', urllib.parse.urlencode(params).encode("utf-8"))
try:
except:
editSvcURL = baseURL + '/admin/services/' + serviceName + '.MapServer/edit'
