Hello. I am currently having a very odd issue with ArcPro v.2.4.3
I have been unable to select a feature using the Selection tool for a long time and finally want to try and get this resolved. I can select features using the attribute table without any issues.
In the Contents Pane, under List by Selection the layer is checked.
I have right-clicked on the layer, and clicked on "Make this the only selectable layer" - Still can't click on anything
It doesnt matter if I try on a layer from the SDE or a Shapefile I cant select any features.
This thread sounds like the user is having a similar issue but its a much older version of ArcMap https://community.esri.com/thread/9883
If any screenshots would help just let me know and I will provide them.
Thanks.
EDIT: WOW! ok my issue is resolved and it was that old post that helped. I thought I had looked at this already but under Selection> Interactive Selection Method the type was set to "Remove from current selection."
