Table is not multiversioned error
5529
12
12-13-2022 08:52 AM
DrewGuardi
I am trying to edit the vertices of line segments in a layer.  After I modify the vertices and try to save the edit I get the following error:  "Modify vertices failed.  The table is not multiversioned."  I've attached a screen shot of the error message.  How do I go about fixing this?
Craig_Schellenbach
FYI: I also got this error when we tried to use the Append tool into a versioned SDE database when the shapefile we were importing was in a different coordinate system.
@DaraBurlo 🙂
VickyS
This error occurs when we add a new feature class to a feature dataset that is already versioned.  The fix is to go to the feature dataset 'manage' options and tick 'versioned'.
The box has a white fill when the feature dataset has versioning enabled but contains non versioned feature classes. If versioning is enabled on all feature classes it displays a tick.
A warning to reenable versioning when created a new dataset would be useful.
KeithAddison1
I seemingly get this error at random since upgrading to 3.2.  I'll try to edit a field and it will fail with this message.  I'll close, reopen and it will not be a problem for a bit then come up again for some reason.  Sometimes field calculator can do the edit where the manual attempt fails.  No one else has and edit session going on this data or is even looking at it.  Nothing about our data has ever been versioned or registered as such, so why would this come up?
