When running ArcGIS Pro on my M1 Mac with Parallels, I'm unable to clone my default Python environment. I keep getting the following error:
> "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\conda.exe" create --clone "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3" -p "C:\Users\alexdevoid\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone" --no-shortcuts --pinned --yes
Installing package 'traitlets' into environment
Installing package 'prompt_toolkit' into environment
Installing package 'chardet' into environment
Installing package 'jupyter_server' into environment
Installing package 'requests' into environment
Installing package 'pro_notebook_integration' into environment
Installing package 'soupsieve' into environment
Installing package 'charset_normalizer' into environment
Installing package 'prometheus_client' into environment
Installing package 'html5lib' into environment
Installing package 'attr' into environment
Installing package 'websocket' into environment
Installing package 'pyrsistent' into environment
Installing package 'ipython_genutils' into environment
Installing package 'bleach' into environment
Installing package 'gapy' into environment
Installing package 'anyio' into environment
Installing package 'jinja2' into environment
Installing package 'nbclassic' into environment
Installing package 'winpty' into environment
Installing package 'jupyterlab' into environment
Installing package 'nbformat' into environment
Installing package 'debugpy' into environment
Installing package 'ipykernel' into environment
Installing package 'certifi_win32' into environment
Installing package 'psutil' into environment
Installing package 'parso' into environment
Installing package 'brotli' into environment
Installing package 'dateutil' into environment
Installing package 'urllib3' into environment
Installing package 'tornado' into environment
Installing package 'bs4' into environment
Installing package 'wcwidth' into environment
Installing package 'zmq' into environment
Installing package 'yaml' into environment
Installing package 'nbclient' into environment
Installing package 'jupyterlab_server' into environment
Installing package 'importlib_metadata' into environment
Installing package 'packaging' into environment
Installing package 'mistune' into environment
Installing package 'sniffio' into environment
Installing package 'jupyter_contrib_nbextensions' into environment
Installing package 'jupyter_client' into environment
Installing package 'jupyter_core' into environment
Installing package 'fastjsonschema' into environment
Installing package 'defusedxml' into environment
Installing package 'colorama' into environment
Installing package 'bapy' into environment
Installing package 'backcall' into environment
Installing package 'pygments' into environment
Installing package 'jupyterlab_pygments' into environment
Installing package 'send2trash' into environment
Installing package 'certifi' into environment
Installing package 'jsonschema' into environment
Installing package 'notebook_shim' into environment
Installing package 'wrapt' into environment
Installing package 'despatch' into environment
Installing package 'terminado' into environment
Installing package 'webencodings' into environment
Installing package 'arcgisscripting' into environment
Installing package 'x86cpu' into environment
Installing package 'lxml' into environment
Installing package 'mkl' into environment
Installing package 'jupyter_nbextensions_configurator' into environment
Installing package 'markupsafe' into environment
Installing package 'arcpy_wmx' into environment
Source: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
Destination: C:\Users\alexdevoid\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
Packages: 437
Files: 2021
Copying pinned file from C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\conda-meta\pinned to C:\Users\alexdevoid\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\conda-meta\pinned
Downloading and Extracting Packages
tensorflow-base-2.7. | | 0%
InvalidArchiveError("Error with archive C:\\Users\\alexdevoid\\AppData\\Local\\ESRI\\conda\\pkgs\\tensorflow-base-2.7.0-py39_cuda11.1_cudnn8.1_6.tar.bz2. You probably need to delete and re-download or re-create this file. Message was:\n\nfailed with error: [WinError 206] The filename or extension is too long: 'C:\\\\Users\\\\alexdevoid\\\\AppData\\\\Local\\\\ESRI\\\\conda\\\\pkgs\\\\tensorflow-base-2.7.0-py39_cuda11.1_cudnn8.1_6\\\\Lib\\\\site-packages\\\\tensorflow\\\\include\\\\external\\\\cudnn_frontend_archive\\\\_virtual_includes\\\\cudnn_frontend\\\\third_party\\\\cudnn_frontend\\\\include\\\\contrib\\\\nlohmann'")
Cleaning up...
Destination folder removed.
Anyone have any clue what's going on?
I've already run ArcGIS Pro as an administrator and I've given write permissions to the cloned environment's destination.
