I just recreated some of my attribute rules from ArcMap to ArcPro and I'm noticing some differences. The one that's giving me the most heartburn right now is the "Editable" check box on the rule.
I have a few rules that grab attribute values from other underlying feature classes so when you place an address point or move it, it grabs the Municipality and the Parcel ID. Works really well. But sometimes we need to manually override this value, because reasons, and even though I have the "Editable" check box on, it doesn't let me overwrite a new value by hand, it just flips it back to the original value.
Is this because I have the "Update" check box on as well, so it thinks it has to run the rules again because I updated the record and you're caught in an impossible Catch-22? Didn't we used to have an option to update only when the shape changed? Because that's what I want to do. I only want to update certain values when they get created or moved, but not just becuase some of the other attributes changed. Is that possible somehow?
