No idea. If it’s possible to do it with TINs though, do it. At least with other layers which could be surfaces, like .TIF files, have it as a step during adding it to the data frame that you can choose to use elevation values from that surface rather than automatically overlaying it on the surface defined already as ‘ground’.
This message is the property of Amec Foster Wheeler plc and/or its subsidiaries and/or affiliates and is intended only for the named
recipient(s). Its contents (including any attachments) may be confidential, legally privileged or otherwise protected from disclosure
by law. Unauthorised use, copying, distribution or disclosure of any of it may be unlawful and is strictly prohibited. We assume
no responsibility to persons other than the intended named recipient(s) and do not accept liability for any errors or omissions which
are a result of email transmission. If you have received this message in error, please notify us immediately by reply email to the
sender and confirm that the original message and any attachments and copies have been destroyed and deleted from your system. This
disclaimer applies to any and all messages originating from us and set out above. If you do not wish to receive future unsolicited
commercial electronic messages from us, please forward this email to: unsubscribe@amecfw.com and include “Unsubscribe” in the subject
line. If applicable, you will continue to receive invoices, project communications and similar factual, non-commercial electronic communications.
Please go to http://amecfw.com/email-disclaimer for notices and company information in relation to emails originating in the UK, Italy or France.
