ArcGIS Pro SDK - Select feature from FeatureLayer
3063
10-31-2019 09:10 AM
OscarDiago_Alonso
Hi!
I want to select a feature from a FeatureLayer using a query and I can't find any example of it.
The closest code snippet I have found uses somekind of selection by intersection, but that is not going to work for me:
 Dim qf As QueryFilter = New QueryFilter()
qf.WhereClause = "Filed1= " & myVariable
Using rowCursor As RowCursor = fEdif.Search(qf)
    While rowCursor.MoveNext()
         Dim feature1 As Feature = TryCast(rowCursor.Current, Feature)
         Dim geo As ArcGIS.Core.Geometry.Geometry = feature1.GetShape()
          MapView.Active.SelectFeatures(geo)
     End While
End Using‍‍‍‍‍‍‍‍‍‍‍‍‍
That way the building I want is selected, but also the ones that are attached to it.
So, how can I just select the feature that is returned by the search?
The FeatureLayer has a method called SetSelection, but I can't find any example of how to use it.
Thanks for any help provided!!
GKmieliauskas
Hi Oscar,
You do not need any code snippet. Just use Select method from FeatureLayer. Like that:
featLayer.Select(qf); // your query filter
GKmieliauskas
Hi Oscar,
OscarDiago_Alonso
Thanks!
I got the wrong idea that that method only worked with QuerySpatialFilter.
