I've been playing around with Pro and I really like both the product and the SDK. However, there's one problem with the latter - it's extremely difficult to write unit tests around it. I'd like to suggest a few enhancements to make it support unit testing. I've got a whole bunch of examples to illustrate what I'm talking about, but note that I got carried away writing code and none of it has been run through a compiler. It's probably horribly broken.
The most important (and easiest!) change to make is to extract interfaces for as many classes as you can. Here's an example that I took from the wiki on GitHub and wrapped up in a class.
public class FeatureLayerCounter
public int GetCityLayerCount()
var count = await QueuedTask.Run(() =>
QueryFilter qf = new QueryFilter()
WhereClause = "Class = 'city'"
//Getting the first selected feature layer of the map view
var flyr = (FeatureLayer)MapView.Active.GetSelectedLayers().OfType<FeatureLayer>().FirstOrDefault();
RowCursor rows = flyr.Search(qf);//execute
//Looping through to count
int i = 0;
while (rows.MoveNext()) i++;
return i;
return count;
Let's say I wanted to test the part where it counts up the rows that were returned in order to make sure I don't introduce an off-by-one error or something. With the code written the way it is now, that simply isn't possible because I don't have an active map in a unit test. I also don't really want to instantiate a QueryFilter object or call any of the other SDK functions because I only want to test the logic that I've implemented. Here's one possible refactoring to make it easier to test.
IMapView activeMapView = MapView.Active;
IQueryFilter qf = new QueryFilter()
return CountLayers(activeMapView, qf);
return count;
internal int CountLayers(IMapView activeMapView, IQueryFilter qf)
var flyr = (IFeatureLayer)activeMapView.GetSelectedLayers().OfType<IFeatureLayer>().FirstOrDefault();
IRowCursor rows = flyr.Search(qf);//execute
int i = 0;
return i;
In this version, I've introduced interfaces for MapView, QueryFilter, FeatureLayer, and RowCursor. I've also extracted a portion of the code and moved it to its own function (CountLayers) so I have a place to inject some mock objects. (As an added bonus, the new function is also more generic than the original!) Now I can directly invoke CountLayers from a unit test without calling MapView.Active, and I can also set up mock objects for all of the stuff from the SDK. Here's what a unit test might look like if written with NUnit, NSubstitute, and FluentAssertions.
public class FeatureLayerCounterTests
[Test]
public void CountLayers_OneMatchingLayer_ReturnsOne()
// Create some mock objects
var queryFilter = Substitute.For<IQueryFilter>();
var activeMapView = Substitute.For<IMapView>();
var selectedLayer = Substitute.For<IFeatureLayer>();
var selectedLayers = new List<IFeatureLayer> { selectedLayer };
var rows = Substitute.For<IRowCursor>();
// Set them up so the function eventually calls MoveNext() on our mock rows object.
selectedLayer.Search(queryFilter).Returns(rows);
activeMapView.GetSelectedLayers().Returns(selectedLayers.AsReadOnly());
// TODO: rows.MoveNext() must be set up to return true the first time it is called, and false the second time.
// This is by far the most important part, but let's ignore the details for this example.
// Run the function under test.
var featureLayerCounter = new FeatureLayerCounter();
var actualCount = featureLayerCounter.CountLayers(activeMapView, queryFilter);
actualCount.Should().Be(1);
If the Pro SDK is tweaked so that the classes all implement interfaces, then everything works as above and everyone is happy. So what if the SDK remains the way it is now? Well, the same techniques can still be used, but the end developers need to write and maintain an extra layer of cruft that they shouldn't need to. Interfaces can be introduced manually by creating thin proxy classes that have the same interface as the classes from the SDK. For example, to create the IRowCursor interface I used above, I could do something like the following.
public interface IRowCursor
bool MoveNext();
public class RowCursorProxy : IRowCursor
internal RowCursor ProxyTarget { get; private set; }
public RowCursorProxy(RowCursor rowCursor)
ProxyTarget = rowCursor;
public bool MoveNext()
return ProxyTarget.MoveNext();
There's an interface that has the function(s) I need and a concrete implementation that wraps a RowCursor from the SDK. It's fairly simple in this case, but it's still more code to maintain. Things get more complicated for classes that use other classes from the SDK. Here's how IFeatureLayer would be implemented.
public interface IFeatureLayer
IRowCursor Search(IQueryFilter);
public class FeatureLayerProxy : IFeatureLayer
internal FeatureLayer ProxyTarget { get; private set; }
public FeatureLayerProxy(FeatureLayer featureLayer)
ProxyTarget = featureLayer;
public IRowCursor Search(IQueryFilter queryFilter)
// Unwrap the input.
var qf = (queryFilter as QueryFilterProxy).ProxyTarget;
// Call the proxied function.
var rc = ProxyTarget.Search(qf);
// Wrap the output.
return new RowCursorProxy(rc);
The other big problem with the Pro SDK is the use of static functions and factories. You can't mock a static function, which means there's no place to inject anything if you're calling a static factory method. The only choices you have are to wrap the call to the factory in a virtual member function, or use the abstract factory pattern. Here's an example of some code that uses the ColorFactory class from the SDK. The first function uses it directly, while the second function uses an abstract factory to hide it.
public class ColorfulThing
public int PrettyColors1()
// Generate a random color using the static CreateRGBColor function from ColorFactory.
var r = Random.NextDouble();
var g = Random.NextDouble();
var b = Random.NextDouble();
var a = Random.NextDouble();
var color = ColorFactory.CreateRGBColor(r, g, b, a);
// Do something with the color here and return the result.
return x;
public int PrettyColors2(IColorFactory abstractColorFactory)
// Generate a random color using the non-static CreateRGBColor function from IColorFactory.
var color = abstractColorFactory.CreateRGBColor(r, g, b, a);
return x;
And here are some unit tests to verify the behavior when the randomly-generated color is black. (Spoiler: it can't be done with the regular static factory.)
public class ColorfulThingTests
[Test]
public void PaintItBlack1()
// Let's make sure the function returns 0 when the color is black.
var ct = new ColorfulThing();
var x = ct.PrettyColors1();
x.Should().Be(0); // Hmm, PrettyColors1 always uses a random color, so chances are this will fail.
[Test]
public void PaintItBlack2()
// This is solid black.
var black = new CIMRGBColor { R = 0, G = 0, B = 0, Alpha = 1 };
// Make a mock factory that generates black, no matter what parameters it was given.
var colorFactory = Substitute.For<IColorFactory>();
colorFactory.CreateRGBColor(Arg.Any<float>(), Arg.Any<float>(), Arg.Any<float>(), Arg.Any<float>()).Returns(black);
x.Should().Be(0); // This time we're absolutely sure it's using black.
The solution for this is the same whether it's done in the SDK or by the end developer. You simply make an interface that has the same signature(s) as the static factory function(s), and then provide an implementation of it that calls the normal static version. The user instantiates the abstract factory and calls that, rather than going straight to the static one.
public interface IColorFactory
CIMColor CreateRGBColor(float r, float g, float b, float a);
public class AbstractColorFactory : IColorFactory
public CIMColor CreateRGBColor(float r, float g, float b, float a)
return ColorFactory.CreateRGBColor(r, g, b, a);
And there you have it! With the help of a refactoring tool like Resharper, the ArcGIS Pro SDK can easily become a test-friendly powerhouse! (And therefore, more developer-friendly!) An extra big thank you goes out to anyone who's read all the way to the bottom of this post.
-Mark
