I am using the Esri.ArcGISPro.Extensions NuGet package to build my ArcGIS Pro add-in without a physical ArcGIS Pro install (https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-ArcGIS-Pro-Extensions-NuGet). This does seem to work great for compiling my add-in.
However, I also have existing unit tests (https://github.com/esri/arcgis-pro-sdk/wiki/ProGuide-Regression-Testing) that are now failing because they still try to reference the ArcGIS Pro install:
This is what the MSTest section in my .runsettings file looks like:
<MSTest>
<TestTimeout>90000</TestTimeout>
<MapInconclusiveToFailed>false</MapInconclusiveToFailed>
<CaptureTraceOutput>true</CaptureTraceOutput>
<DeleteDeploymentDirectoryAfterTestRunIsComplete>true</DeleteDeploymentDirectoryAfterTestRunIsComplete>
<DeploymentEnabled>false</DeploymentEnabled>
<AssemblyResolution>
<Directory path="C:\Program Files\ArcGIS\Pro\bin\" includeSubDirectories="true"/>
</AssemblyResolution>
</MSTest>
Is it possible to point the AssemblyResolution to the Esri.ArcGISPro.Extensions NuGet package, or do the ArcGIS Pro unit tests require ArcGIS Pro to be installed on the same machine?
Greg
