today I checked out the proConfigX file of our ArcGIS Pro application and it turns out that even though I built it in release-mode, it contained PDB files of the ArcGIS Pro application and also of the dependencies. I also found XML files of dependencies with the comments generated by VS.
I don't really think it makes sense to include these files in the release target so I wonder if there's an easy way to exclude them or if I have to modify the build process so that these files are wiped before the proConfigX is put together (which is only a zip file with a special structure, if I'm not mistaken).
Thanks in advance
Christian
