In ArcGIS Pro version 2.0.0 I use this code to execute merge tool
public async Task<bool> ExecuteToolAsync()
var valueArray = await QueuedTask.Run(() =>
// Creates a 8000-meter buffer around the geometry object
// null indicates a default output name is used
return Geoprocessing.MakeValueArray(_inputs, _output);
var result = await Geoprocessing.ExecuteToolAsync("Merge_management", valueArray);
return !result.IsFailed;
where _inputs is list of fullpath of layers
it works well.
but to execute intersect tool i use this:
var _inpputs= new List<string>() { _featureLayer1, _featureLayer2 };
var valueArray = await QueuedTask.Run(() => Geoprocessing.MakeValueArray(_inpputs, _outputFeatureClass, "ALL, "0", "POINT"));
var result = await Geoprocessing.ExecuteToolAsync("Intersect_analysis", valueArray);
It doesn't work. How can I solve this.
