I am trying to use a GP tool to export a Layer to a File GDB. Is there a way to find which layers are already present in the GDB so that I can give a different name to my Layer. The code below works but was hoping there is a better way to do this.
thank you,
Vijay
string featureClassName = AppConstants.ExportProposedBuildingName;
IReadOnlyList<string> valueArray = null;
await QueuedTask.Run(() =>
Geodatabase fileGeodatabase = new Geodatabase(@"c:\0_Projects\CapeCodCommission\CapeCod.gdb");
bool isFound = true;
int index = 0;
while (isFound)
try
fileGeodatabase.OpenDataset<Table>(featureClassName);
isFound = true;
featureClassName = AppConstants.ExportProposedBuildingName + "_" + ++index;
catch
isFound = false;
valueArray = Geoprocessing.MakeValueArray
(proposedBuildingLayer, @"C:\0_Projects\CapeCodCommission\CapeCod.gdb\" + featureClassName);
Hi Vijay,
You can use the GetDefinitions (ArcGIS Pro 1.2 API Reference Guide) method instead. The Definition is a much lighter weight construct which does not open the feature class. One more thing to remember is that getting the TableDefinitions will not give you the FeatureClassDefinitions.
Try the following code out. It uses the LINQ syntax for more concise code.
List<Definition> definitions = new List<Definition>();
definitions.AddRange(fileGeodatabase.GetDefinitions<TableDefinition>());
definitions.AddRange(fileGeodatabase.GetDefinitions<FeatureClassDefinition>());
int index = 0;
while(definitions.Any(definition => definition.GetName().Equals(featureClassName)))
-Sree
Hi Vijay,
int index = 0;
-Sree
Thank you Sree!! That was exactly what I needed!
