How can I browse the API documentation offline?
1870
02-09-2017 04:48 AM
ChristopheAndrey1
As a developer using the ArcGIS Pro SDK, I find myself often browsing through the online API reference. Even with my best internet connection, it takes 1-3 seconds for each page to appear. However, I am often working with a weak internet connection, and then I have to wait several seconds after each mouse click until the desired page appears. When I am exploring the API in the search of "some method that would fit my need", this is very tedious.
I come originally from the Java development. There, every API reference can be downloaded in a Zip file and then browsed on one's computer. I would expect the same level of comfort from Esri. Am I asking for too much?
PS: I tried mirroring the API reference with wget but somehow what wget downloaded was barely readable at the end.
UmaHarano
Hi Christophe
You can download the the ArcGIS Pro SDK chm file and then use it on your computer.
From this page (https://github.com/Esri/arcgis-pro-sdk/releases ) scroll to the bottom of the ArcGIS Pro 1.4 SDK for .NET section and then click to download the ArcGISProAPIReference.chm file.
Uma
ArcGIS Pro SDK Team
ChrisStayte
You can download the references at this Git-Hub Link. It is at the bottom of the page. Release ArcGIS Pro 1.4 SDK for .NET · Esri/arcgis-pro-sdk · GitHub
UmaHarano
Hi Christophe
Uma
ArcGIS Pro SDK Team
MaxMax2
Occasional Contributor II
Hi Uma,
What about MSHA help file to view it in Microsoft Help Viewer? Will it be provided in the future or you plan to provide CHM only? It is more convinient to view all help in one place.
UmaHarano
Hi Max,
We do not have the MSHA help file for ArcGIS Pro SDK.
Uma
