How to customize the icon of a custom module in ArcGIS Pro SDK
1299
05-11-2020 05:22 AM
Amadeus111
Occasional Contributor II
I created a customized ArcGIS Pro module and everything works fine but I also would like to create a customized icon for the module.
I found this resource but it does not work for me
ProGuide Content and Image Resources · Esri/arcgis-pro-sdk Wiki · GitHub
using System.Windows.Media.Imaging;
using System.IO.Compression; //Image is defined as AddinContent.//AddinContent is ESRI custom build action. Cannot use without Addin
BitmapImage forAddinContent = new BitmapImage();
string id = "{49545510-2f4a-4e9c-bc12-3ea79a330fa0}";//From your module
using (ZipArchive zip = ZipFile.OpenRead(
   @"C:\Users\my_username\Documents\ArcGIS\AddIns\ArcGISPro\" + id +
   @"\AddinContent.esriAddInX")) {
   ZipArchiveEntry zipEntry = zip.GetEntry("Images\AddInDesktop32.png");
   MemoryStream ms = new MemoryStream();
   using (Stream stmZip = zipEntry.Open())
    { stmZip.CopyTo(ms);}
      forAddinContent.BeginInit();
      forAddinContent.StreamSource = ms;
       forAddinContent.EndInit(); }
I get zipEntry = null error
Is there way to customize a module's icon?
Thanks!
Amadeus111
It was easier than I thought. I just needed to read the document more carefully. When I set the build action to "AddinContent"  for the image and use the relative path for the image in Config.daml problem solved.
here is more info about build actions Build actions for files - Visual Studio | Microsoft Docs
Amadeus111
