Is it possible to reuse query definition building dialog
910
06-15-2017 07:59 AM
GKmieliauskas
I would like to reuse query definition building dialog in my application to let user build your own query to collect objects for calculations. That whereclause string will be frequently used and will be saved to database to remember. So customer do not need to make selection by attribute each time. ArcGIS Pro layer Properties command has property page for building queries.
Is there API to use that dialog? It is possible to use query definition building dialog from ArcMap ArcObjects.
CharlesMacleod
Hi Gintautas, Providing a query definition control for re-use on your own UIs in the backlog. I will update this thread with a more definite status post-UC.
No, not possible
AndrewGilbert
@CharlesMacleod Can you provide an update on this? Thanks.
CharlesMacleod
