I have an ArcGIS Pro button add-in that opens a WPF window when clicked. If I wrap the OnClick handler code in QueuedTask.Run() the CIM works and I'm able to pan/zoom in the map view, but the TOC is still disabled.
I would like the user to be able to turn layers on/off and move the order around while the window is open. How might I enable this? When I use a dockpane this seems to be automatic but now I'm opening a (non-ArcGIS) WPF window.
internal class ShowExporterWindow : Button
ExporterWindow window;
protected override void OnClick()
QueuedTask.Run(() => {
window = new ExporterWindow();
window.ShowDialog();
