Hi Ted,
Here is a way to customize the disabedText property of a button\tool:
* Set the tool's loadOnClick attribute to "false" in the config.daml. This will allow the tool to be created when Pro launches. This way the disabledText property can display customized text at startup.
* Remove the "condition" attribute from the tool. You will be using the OnUpdate method to set the enable\disable state of the tool.
* Add the OnUpdate method to the tool. The code for it will be something like this:
protected override void OnUpdate()
bool enableSate = true; //TODO: Code your enabled state
bool criteria1 = true; //TODO: Evaluate criteria for disabledText
bool criteria2 = false; //TODO: Evaluate criteria
bool criteria3 = true; //TODO: Evaluate criteria
if (enableSate)
this.Enabled = true; //tool is enabled
else
this.Enabled = false; //tool is disabled
//customize your disabledText here
if (criteria1)
this.DisabledTooltip = "Missing criteria 1";
else if (criteria2)
this.DisabledTooltip = "Missing criteria 2";
else if (criteria3)
this.DisabledTooltip = "Missing criteria 3";
Note: since OnUpdate is called very frequently, you should avoid lengthy operations in this method as this would reduce the responsiveness of the application user interface.
Uma Harano
ArcGIS Desktop SDK Team
