What is the difference between CanEditData() and IsEditable?
230
02-26-2024 06:48 AM
Amadeus111
Occasional Contributor II
I need to check if a FeatureLayer editable and convey a message to the user if editing fails for a feature. I would like to show a meaningful reason why the FeatureLayer is not editable.
I thought CanEditData() returns false for only if user unchecks editable checkbox on Contents pane but that is not I found out. So, what is the difference between these two other than one is method, the other is property? They basically check the same thing?
LukeBettis
I would also like to know the answer to this, I have a feature layer with IsEditable true and CanEditData() returning false. What's the difference between the two?
GKmieliauskas
Text from ProConcepts:
"Edits can be attempted on all editable layers and standalone tables, i.e. MapMembers, determined by the CanEditData property on BasicFeatureLayer, StandAloneTable and IDisplayTable. This property is a combination of the editability of the data source (read/write), and the IsEditable property of those classes which represents the check box state on the List by Editing view of the table of contents."
ProConcepts Editing · Esri/arcgis-pro-sdk Wiki · GitHub
