Attachments throw error: Server Error - The remote server returned an error: (500) In
2792
08-17-2012 12:22 PM
JamesLandwehr
New Contributor III
When trying to access a REST endpoint with attachments, I am getting a 500 error that reads:
"Server Error - The remote server returned an error: (500) Internal Server Error."
These attachments are stored in a SDE SQL Server database and are served in a dynamic map service using an .msd. They can be opened in the .mxd with no problems.
Any ideas on what to check?
JamesLandwehr
New Contributor III
It turns out this was a problem with the arcgisoutput virtual directory pointing to a bad path.
JamesLandwehr
New Contributor III
JonGarrido
New Contributor III
Hi James,
I've posted two threads of your own about this. How did you resolved this issue?
How cana I modify to correct this arcgisoutput directory??
Thanks in adavance,
Jon
JamesLandwehr
New Contributor III
Jon,
In our case, when AGS was installed, we set F:\arcgisserver as the default arcgisserver folder. (i.e. F:\arcgisserver\arcgisoutput) Whenever an upgrade was done, it reset this back to C:\arcgisserver which would not be recognized by the application when looking for the attachments in the F:\ folder. Once I set it back to F:\ the error went away. (You must make sure that the F:\ folder has the correct permissions, etc.)
So, I think the issue in our case was specific to our custom installation of AGS.
Jim
JonGarrido
New Contributor III
Thanks Jim,
I'll work on this clue....
