I have this process that runs daily, where I get some values from an external source, I transform & store them in a local DB. I then match existing values on AGOL to this local table to make sure the objectids are the same (just to make sure everything is in sync) and add new objectids sequentially locally from the last existing one on AGOL. Then I append (with python) this data to my AGOL table (upload_format = 'geojson', upsert = True, edits = the results from a query on my local DB).
This was running fine, every day, until last week, when I started getting an Exception: Unknown Error (Error Code: 500). The sync and changeTracking parameters are deactivated and I've tried deleting and recreating the table (multiple times)...
What to do?
Please help!
EDIT march 11th
Working with ESRI staff on this, will update with developments. Also noticed that I only have this problem with tables, appending to layers is working correctly.
