Before I used the Web ADF to add the custom graphics to the map description and then use ExportMapImage to get the generated map image. Since Web ADF will be obsolete in future versions of ArcGIS Server I need another method to do this. The only way I know to export map is to use the REST API. Do you know a way to do this without using the Web ADF? Thanks.
