I am using ArcGIS REST Api version 10.6.1.
I have the following problem: Geometries are not displayed in 3D mode because the requests may be incorrect. In 2D mode (MapView) everything works fine.
My analysis:
If I do not support queries with returnCountOnly & returnIdsOnly in the query interface, then everything works. So if I return an empty object in the following query:
Request:
http://localhost:8080/rest/arcgis/features/4242/4242/query?f=json&returnIdsOnly=true&returnCountOnly...
Response:
As soon as I return an object with the Count value as usual it doesn't work.
{"count": 1}
Because the subsequent requests then look like this:
Request:
http://localhost:8080/rest/arcgis/features/4242/4242/query?f=json&outFields=objectId%2Cdescription&outSR=102100&spatialRel=esriSpatialRelIntersects&where=1%3D1
But I don't want to support query calls without a geometry.
My expected subsequent request would be:
http://localhost:8080/rest/arcgis/features/4242/4242/query?f=json&geometry=<geometry>&maxAllowableOffset=3261.313206833336&outFields=objectId%2Cdescription&outSR=102100&spatialRel=esriSpatialRelIntersects&where=1%3D1&geometryType=esriGeometryEnvelope&inSR=102100
I also get the following error message on #fetchTile():
What is the best way to solve the problem? I don't want to remove the returnCountOnly function from the interface.
Why does it work at all if I return something wrong (empty object) so to speak?
Thanks for any help!
*** EDIT ***
I found out that when the feature count is over 50,000 that the request is split into multiple requests.
So where does the limit "50,000" come from and how can I override it?
I didn't find anything about this in the docs.
