I have a msd that I'm serving. It has two layers in it (Signs and Sign Supports). When I symbolize these layers on any field (other than the subtype field) all is good. I'm publishing them with Feature access capabilities so I can consume them in a web browser and edit.
If I try to symbolize on the subtype field. THE FEATURE LAYER DOESN"T GET CREATED (see attachment). It creates the other feature layer that I didn't symbol on subtype. In this case I'm the SIGNS feature class symbolizing on its subtypes, which dictates which type of sign category (domain) will be available. (ex. if subtype 0 is picked that is regulator subtype so the sign type domains are for the regulator signs (R1, R2, R3, etc).
It does create the layer as a mapserver layer and displays it Legend rest api correctly (see attach).
Once I dropped the null values (either in the symbolization and/or in the layer entirely) the problem resolved it self. Null values and symbology doesn't seem to be supported in a Feature Layer or something is buggY?
