I am trying to load the Layer which is secured by a token. I have credentials to generate them and the URL.
I am using
UserCredential userCredential = new UserCredential(user, pass, tokenUrl)
ArcGISMapImageLayer dynamicLayer = new ArcGISMapImageLayer(ms.getServiceUrl());
dynamicLayer.setCredential(userCredential);
dynamicLayer.setRequestConfiguration(requestConfiguration);
And I am getting as response: 401 Unauthorized. Token Require.
Lib doesn't even try to make a request, and generate token before loading layer. I checked it in Proxyman.
In previous (10.x) library I used
UserCredentials userCredentials = new UserCredentials();
userCredentials.setTokenServiceUrl(tokenUrl)
userCredentials().setUserAccount(user, pass)
ArcGISFeatureLayer featureLayer = new ArcGISFeatureLayer(url, mode, userCredentials);
Lib made a call to {tokenUrl},
Then it was loading layer with parameter {token} in URL.
There is any possibility to fix this issue? Same situation with WMSLayer, ServiceFeatureTable, ArcGISMapImageLayer, ArcGISTiledLayer.
