Version : arcgis-android:100.14.0
I have a switch to load satelite map in my app. It was working fine until some android update.
Now it throws an error and crashes the App. It shows ' com.esri.arcgisruntime.ArcGISRuntimeException: Object is already owned.: Already owned.'
I tried clearing the Layers before adding it again. I'm new in this space. kindly go through my code and see if I could do it in a better way.
--------- beginning of crash
2022-07-27 12:34:58.626 19151-19151/com.example.administrator.loccy E/AndroidRuntime: FATAL EXCEPTION: main
Process: com.example.administrator.loccy, PID: 19151
at com.esri.arcgisruntime.internal.jni.CoreFeatureLayer.nativeCreateWithFeatureTable(Native Method)
at com.esri.arcgisruntime.internal.jni.CoreFeatureLayer.<init>(SourceFile:96)
at com.esri.arcgisruntime.layers.FeatureLayer.a(SourceFile:4)
at com.esri.arcgisruntime.layers.FeatureLayer.<init>(SourceFile:21)
at com.dubaipolice.loccy.activities.MainActivity.setupMap(MainActivity.java:470)
at com.dubaipolice.loccy.activities.MainActivity.switchMap(MainActivity.java:555)
at com.dubaipolice.loccy.ResourceTypeDialogFragment$1.onClick(ResourceTypeDialogFragment.java:95)
at android.view.View.performClick(View.java:7792)
at android.widget.TextView.performClick(TextView.java:16112)
at android.widget.CompoundButton.performClick(CompoundButton.java:157)
at android.view.View.performClickInternal(View.java:7769)
at android.view.View.access$3800(View.java:910)
at android.view.View$PerformClick.run(View.java:30213)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:226)
at android.os.Looper.loop(Looper.java:313)
at android.app.ActivityThread.main(ActivityThread.java:8663)
at java.lang.reflect.Method.invoke(Native Method)
at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:567)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:1135)
final ArcGISMapImageLayer PolyLayer = new ArcGISMapImageLayer("http://XXXXXX");
ArcGISTiledLayer tiledLayerBaseMap = new ArcGISTiledLayer("http://XXXXXX");
ServiceFeatureTable serviceFeatureTable = new ServiceFeatureTable("http://XXXXXX");
ServiceFeatureTable resZoneFeatureTable = new ServiceFeatureTable("http://XXXXXX");
ArcGISMap map = new ArcGISMap();
public void switchMap() { //calls on change on switch
mMapView.getGraphicsOverlays().remove(resGraphicsOverlay);
mMapView.getGraphicsOverlays().remove(eventGraphicsOverlay);
map.getOperationalLayers().clear();
setupMap();
private void setupMap() {
if (getBooleanFromSP("satMapON")) {
Log.i("SAVL","SATMAPON");
Basemap basemap = new Basemap(PolyLayer);
map = new ArcGISMap(basemap);
map.setBasemap(basemap);
mMapView.getGraphicsOverlays().add(resGraphicsOverlay);
mMapView.getGraphicsOverlays().add(eventGraphicsOverlay);
mMapView.setMap(map);
FeatureLayer featureLayer1 = new FeatureLayer(serviceFeatureTable);
FeatureLayer resFeatureLayer1 = new FeatureLayer(resZoneFeatureTable);
SimpleLineSymbol lineSymbol = new SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, Color.rgb(252, 255, 164), 1);
SimpleRenderer simpleRenderer = new SimpleRenderer(lineSymbol);
resFeatureLayer1.setRenderer(simpleRenderer);
map.getOperationalLayers().add(featureLayer1);
map.getOperationalLayers().add(resFeatureLayer1);
SimpleLineSymbol lineSymbol2 = new SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, Color.rgb(0, 0, 255), 2);
SimpleRenderer simpleRenderer2 = new SimpleRenderer(lineSymbol2);
featureLayer1.setRenderer(simpleRenderer2);
MapViewTouchListener mMapViewTouchListener = new MapViewTouchListener(this, mMapView);
mMapView.setOnTouchListener(mMapViewTouchListener);
else if (!getBooleanFromSP("satMapON")) {
Log.i("SAVL","SATMAPOFF");
Basemap basemap = new Basemap(tiledLayerBaseMap);
FeatureLayer featureLayer2 = new FeatureLayer(serviceFeatureTable);
FeatureLayer resFeatureLayer2 = new FeatureLayer(resZoneFeatureTable);
resFeatureLayer2.setRenderer(simpleRenderer);
map.getOperationalLayers().add(featureLayer2);
map.getOperationalLayers().add(resFeatureLayer2);
featureLayer2.setRenderer(simpleRenderer2);
