Create a basemap from a tiled service (download a basemap) Example
4492
7
11-13-2013 02:41 PM
by Anonymous User
Not applicable
OK I am trying to use the example to build an offline tpk from a tiled service.
https://developers.arcgis.com/en/android/guide/create-an-offline-map.htm#ESRI_SECTION1_286D33A9E13C4...
There are not good examples so I am trying to follow the example from ArcGIS Runtime and adjust it to ArcGIS Runtime for Android.
https://developers.arcgis.com/en/java/sample-code/download-tile-cache-beta/
  The problem I appear to be having is on the CallbackListener.
The line where the issue seems to be happening is  new CallbackListener<TileCacheStatus>() {
where I get the following error....
"java.io.FileNotFoundException: /1029171819/TileCacheStatus:
The code is below....  Any thoughts on what I am doing wrong here.
Envelope extent = new Envelope (-13656926.435,  5702260.809, -13655933.12,  5703167.369);
boolean createAsTilePackage = true;
        // fix this to 5 levels
        double[] levels = {0, 1, 2, 3, 4};
     GenerateTileCacheParameters params = new GenerateTileCacheParameters(
             createAsTilePackage,
             levels,
             ExportBy.ID,
             extent,
             mMapView.getSpatialReference());
tileCacheTask = new TileCacheTask("http://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer", null);
tileCacheTask.submitTileCacheJobAndDownload(
               // parameters
               params,
               // status callback
                 private boolean errored = false;
                 @Override
                 public void onError(Throwable e) {
                   errored = true;
                   //updateProgressBarUI(null, false);
                   e.printStackTrace();
                 @Override
                 public void onCallback(TileCacheStatus status) {
                   if (!errored) {
                    // updateProgressBarUI("Latest status: "+status.getStatus(), true);
               // callback when download complete
               new CallbackListener<String>() {
                 @Override
                   errored = true;
                  // updateProgressBarUI(null, false);
                 @Override
                 public void onCallback(String path) {
                   if (!errored) {
                    // updateProgressBarUI("Tile cache download complete. Switching to local layer...", true);
                    // switchToLocalLayer(path);
                     //tpkButton.setEnabled(true); // re-enable button for another job
               // path for downloaded tile cache
               "file:///storage/extSdCard/Reference_Data/TPK/Test.tpk");
DanO_Neill
Occasional Contributor III
No. I´m just testing a code. This feature only works after the app was licenced ?
You do not need to license your app to use API in developer mode.
I try to run this code with runtime 10.2.3 (using the new ExportTileCacheTask class instead TileCacheTask) but I got the error below
com.esri.core.io.EsriSecurityException: Unauthorized access to a secure service - http://tiledbasemaps.arcgis.com/arcg...iles/submitJob
You need to generate a token to use this service.
DanO_Neill
We are working currently working on a sample for Android and will make it available on ArcGIS Online when it is complete.  Below is some working code for creating the tiles locally by calling submitTileCacheJobAndDownload.
* Creates tile Cache locally by calling submitTileCacheJobAndDownload
* @param params
* @param tileCacheTask
* @param tileCachePath
private void createTileCache(GenerateTileCacheParameters params,
final TileCacheTask tileCacheTask, final String tileCachePath) {
  // Set the recovery directory for incomplete tasks
  tileCacheTask.setRecoveryDir(recoveryDir);
  // estimate tile cache size
  tileCacheTask.estimateTileCacheSize(params,
  new CallbackListener<Long>() {
  @Override
    Log.d("*** tilecachesize error: ", "" + e);
  @Override
  public void onCallback(Long objs) {
    Log.d("*** tilecachesize: ", "" + objs);
// Submit tile cache job and download
tileCacheTask.submitTileCacheJobAndDownload(params, null,
    @Override
      errored = true;
      // print out the error message and disable the progress bar
      Log.d("*** submitTileCacheJobAndDownload error: ", "" + e);
      mProgress.setVisibility(View.GONE);
    @Override
      if (!errored) {
        Log.d("the Download Path = ", "" + path);
        // Disable the progress bar and switch to the
        // successfully downloaded local layer
}, tileCachePath);
// recover all incomplete jobs contained in the recovery directory
tileCacheTask.recoverAllJobs(new CallbackListener<TileCacheStatus>() {
@Override
  Log.d("*** recoverAllJobs error: ", "" + e);
@Override
public void onCallback(TileCacheStatus objs) {
  Log.d("***", " start recovery" + objs);
}, new CallbackListener<String>() {
@Override
@Override
public void onCallback(String objs) {
  Log.d("***", " end recovery" + objs);
by Anonymous User
Not applicable
Dan, Thanks for the assistance.  I was able to get my code to successfully cache.  For anyone interested here is the code that worked for me.  Will definitely need to add a progress bar as the download itself can take awhile.  Will probably need to restrict this tool based on the estimated cache size.
Aaron Dick
Service First Mobile GIS Program Lead
Oregon Washington BLM
USFS Pacific NW Lead
buttonCacheTiles.setOnClickListener(new View.OnClickListener() {
     @Override
     public void onClick(View v) {
      // TODO Auto-generated method stub
      Geometry extent = new Envelope (-13656747.243,  5702686.121, -13656740.229,  5702696.346);
      GenerateTileCacheParameters params = createParameters(extent);
     final String tileCachePath = "/storage/extSdCard/Reference_Data/TPK/Test2.tpk";
       createTileCache(params, tileCacheTask, tileCachePath);
private GenerateTileCacheParameters createParameters(Geometry extent) {
    // double[] levels = {0, 1, 2, 3, 4};
    double[] levels = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16};
     // set up parameters
         levels,
         ExportBy.ID,
         extent,
     return params;
  String recoveryDir = "/storage/extSdCard/Reference_Data/Temp";
     @Override
     @Override
       @Override
         errored = true;
        // mProgress.setVisibility(View.GONE);
       @Override
         if (!errored) {
           //mProgress.setVisibility(View.GONE);
   }, tileCachePath);
   @Override
   @Override
   @Override
   @Override
  private void switchToLocalLayer(final String path) {
    //  SwingUtilities.invokeLater(new Runnable() {
       // @Override
        //public void run() {
       mMapView.removeAll();
        mMapView.addLayer(new ArcGISLocalTiledLayer("file:///storage/extSdCard/Reference_Data/TPK/Test2.tpk"));
LisandroRueckert
New Contributor II
Hello,
com.esri.core.io.EsriSecurityException: Unauthorized access to a secure service - http://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer/exportTiles/submitJo...
The same error has ocurred when I try to run the OfflineTiledLayer example from Java SDK.
Anyone knows what is wrong ?
Thank´s
Lisandro
EdwardLin
New Contributor II
Do you License your app at the Basic level?
LisandroRueckert
New Contributor II
DanO_Neill
by Anonymous User
Not applicable
When I wrote the code above it did not require credentials.  However that changed, so now you must have the code as follows...
UserCredentials credentials;
    credentials = new UserCredentials();
      credentials.setUserAccount(username, password);
    tileCacheTask = new ExportTileCacheTask("http://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer", credentials);
