Thank you very much..If you can explain more the way that i should do from one of the options above it'll very helpful to me.
I read GeoJSON Earthquake Map and Mil2525c Sample on the sample code. But i couldn't find a way to draw curve.
I have some measurements like coordinates of the points where to place on the map, deflection angle between main tangents, radius tangent length etc. But i don't need to use all of those measurements..just some of them and draw the curve.Really i want to draw a railway path on the map.
I looked the Symbol class and in that the Curves only wants 3 points coordinates as start and end points coordinates and the control point coordinate to draw the curve. But here i'm only having start and end coordinates..
