hi,
I'm currently using Arcgis kotlin 200.3.0
Trying to add feature to my geoPackage feature table with the follow code
//GeoPacakge Table
geopackagefeaturetable?.load()?.onSuccess {
Log.d("chris share if can add", geopackagefeaturetable!!.canAdd().toString())
Log.d("chris share if isEditable", geopackagefeaturetable!!.isEditable.toString())
val feature = geopackagefeaturetable?.createFeature(featureAttributes, mapPoint)
?: return showError("Error creating feature using attributes")
// add the feature to the feature table
geopackagefeaturetable?.addFeature(feature)?.onSuccess {
// feature added successfully, update count
featureCountTextView.text =
"Total no of features: ${geopackagefeaturetable?.numberOfFeatures}"
// enable table button since at least 1 feature loaded on the GeodatabaseFeatureTable
viewTableButton.isEnabled = true
}?.onFailure {
showError(it.message.toString())
The issue I have is failure to add feature with error message : message=SQLite read only., additionalMessage=SQLite: 8
Attempt to write a readonly database, errorCode=1008
while geopackagefeaturetable!!.canAdd() and geopackagefeaturetable!!.isEditable() both return true
pls advice
