Is it possible to determine if location is mocked?
803
10-12-2021 11:08 AM
DenisRomanovas
Dear colleagues,
I have quite a big issue 🙂
I use ESRI's LocationDisplay module to get user locations and it seems there is no way to determine if a location is mocked one! I have a big requirement to disallow mocked locations...
Am I right that LocationDisplay module can't tell me if a location is mocked one? Or did I miss something?
If I have a need to filter out mocked locations, should I use native Android GPS methods to get GPS coordinates and abandon ESRI's LocationDisplay?
Any tips maybe? Help would be much appreciated 🙂
ChanganShi1
Yes, the LocationDisplay itself cannot detect if a location is mocked or not. What do you mean to use "native Android GPS methods to get GPS coordinates"? The location display is responsible for displaying a location on the map view, the location data source is the location provider, which is open to extend and wrap any location service, it is also a place to filter out some locations to feed the location display.
ChanganShi1
DenisRomanovas
Thank you for reply! Sounds quite promising if I get it right.
I meant using something like com.google.android.gms.location.FusedLocationProviderClient.
So basically it's quite possible to use something like com.google.android.gms.location.FusedLocationProviderClient as LocationDisplay's location data source, right?
ChanganShi1
Yes, you could extend LocationDataSource by wrapping the FusedLocationProvider, set the new location data source to the location display. By default, the location display uses the  `AndroidLocationDataSource` which wraps the Android LocationManager.
