JsonParseException: Unexpected character ('<' (code 60))
13883
7
06-05-2017 03:58 AM
spkiwijohnson
Hello everyone. The problem is really strange: when loading layers (ArcGISDynamicMapServiceLayer) on the android app using arcgis, the code throws a JsonParseException (as far as I can see it happens when initializing new ArcGISDynamicMapServiceLayer(map.getMapurl());).
The rest and the url is fine, moreover, the app didn't have such issues before, everything worked well. Did someone somehow deal with this?
06-05 07:27:21.746 24663-25710/nl.proclass.docs2go E/ArcGIS: url =http://api.proclass.nl/arcgis/rest/services/Handmatig_Toegevoegd/Handmatig_Toegevoegd/MapServer
org.codehaus.jackson.JsonParseException: Unexpected character ('<' (code 60)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')
at [Source: java.io.StringReader@306f27f; line: 1, column: 2]
at org.codehaus.jackson.JsonParser._constructError(JsonParser.java:1432)
at org.codehaus.jackson.impl.JsonParserMinimalBase._reportError(JsonParserMinimalBase.java:521)
at org.codehaus.jackson.impl.JsonParserMinimalBase._reportUnexpectedChar(JsonParserMinimalBase.java:442)
at org.codehaus.jackson.impl.ReaderBasedParser._handleUnexpectedValue(ReaderBasedParser.java:1198)
at org.codehaus.jackson.impl.ReaderBasedParser.nextToken(ReaderBasedParser.java:485)
at com.esri.core.internal.io.handler.h.a(SourceFile:206)
at com.esri.core.internal.io.handler.h.a(SourceFile:63)
at com.esri.core.internal.tasks.ags.t.a(SourceFile:39)
at com.esri.android.map.ags.ArcGISDynamicMapServiceLayer.initLayer(SourceFile:280)
at com.esri.android.map.ags.ArcGISDynamicMapServiceLayer$1.run(SourceFile:193)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:423)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
at java.lang.Thread.run(Thread.java:818)
AlexanderNohe1
I was able to load :
https://api.proclass.nl/arcgis/rest/services/ATP_BuildingLayouts/ATP_BuildingLayouts/MapServer
on Android using the following snippet:
public class MainActivity extends AppCompatActivity {
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        MapView mapView = (MapView) findViewById(R.id.map);
        mapView.addLayer(new ArcGISDynamicMapServiceLayer("https://api.proclass.nl/arcgis/rest/services/ATP_BuildingLayouts/ATP_BuildingLayouts/MapServer"));
No error was propagated and the layer loaded fine.
AlexanderNohe1
Which version of the runtime are you using?
What is the data type of this object : "map"?
Is this the URL that you are trying to view:
http://api.proclass.nl/arcgis/rest/services/Handmatig_Toegevoegd/Handmatig_Toegevoegd/MapServer ?
spkiwijohnson
The current version is 10.2.9.
map is the entity of MAP_LAYER, the getUrl method actually returns the following url which I mentioned (as well as the other two which also fail):
http://api.proclass.nl/arcgis/rest/services/Handmatig_Toegevoegd_Prive/Handmatig_Toegevoegd_Prive/Ma...
http://api.proclass.nl/arcgis/rest/services/ATP_BuildingLayouts/ATP_BuildingLayouts/MapServer
And yes, that is the url which I am trying to view. The same urls in the iOS don't seem to have any trouble, the problems only started on android about a month ago.
AlexanderNohe1
I see that error as well.  I am also having trouble loading these features in ArcGIS Online Map Viewer or in the ArcGIS Javascript viewer.  Are you facing similar issues there?
spkiwijohnson
ArcGIS Online Map Viewer or ArcGIS Javascript viewer actually show that everything is ok.
http://api.proclass.nl/arcgis/rest/services/ATP_BuildingLayouts/ATP_BuildingLayouts/MapServer this case works out well. Not so good on Android, however.
AlexanderNohe1
    @Override
spkiwijohnson
Thanks a lot, now I see what the problem was. Apparently, I was using the "http" instead of "https". After switching everything went back to normal.
AlexanderNohe1
Nice!  Glad you were able to get this resolved.
