Make a pulse animation PictureMarkerSymbol in android
1010
07-19-2017 11:58 PM
chiragshah4
New Contributor II
I need to make pulse animation with hight and width. Is it possible in android PictureMarkerSymbol?
AlexanderNohe1
Occasional Contributor III
Found some time to write the sample...
Check out this pull request on our developer-support site:
Pulse Graphic Sample in Kotlin by nohe427 · Pull Request #309 · Esri/developer-support · GitHub
AlexanderNohe1
Should be possible.  I see that you have the iOS code available to you as well.  I believe you would need to user the Timer class:  https://developer.android.com/reference/java/util/Timer.html#scheduleAtFixedRate(java.util.TimerTask, long, long)
If I get a chance later today, I will try to come up with a quick sample.  We have been pretty busy over here with the new releases lately so I have not been able to produce as many samples.
AlexanderNohe1
