Map Does Not Appear When Opening App
5031
8
06-26-2014 07:39 AM
GSauers
Hello, I have noticed that sometime when I enter my MapView, the cached map I have set to load does not load, but as soon as you move the grid lines with your finger, the map appears. I never seemed to see this error with 10.1.1, but it occurs with 10.2.3.
This does not happen everytime, but it happens about 40% of the time.
Thank you for any advice and/or help.
GSauers
Has anyone seen this before? Any help please?
GSauers
I am still looking for an answer to this issue. Has anyone see this before or have an advice?
Thank you.
DanO_Neill
Occasional Contributor III
Does it still occur in v10.2.4 or v10.2.5?
GSauers
Thank you for the response Dan, this does still happen in v10.2.4. I have not had the opportunity to upgrade to 10.2.5 yet. Have you seen this before or are you aware of it?
Thanks.
lqdeffx
New Contributor II
I haven't come across this problem myself using 10.2.4.  Might be beneficial to show how the layer is being created.
MengyiGuo
I can not reproduce this issue with 10.2.4 and 10.2.5. Would you like to provide more information about the settings? How is your network settings?
GSauers
Thank you all for your responses, I was seeing the issue again yesterday using 10.2.5. I do not use the network for my maps, I have cached maps for offline use.
Sample of how I add a map:
currentMapLayer = new ArcGISLocalTiledLayer("/sdcard/" + filename + ".tpk");
mapView.addLayer(currentMapLayer);
Thanks again for the help.
MengyiGuo
Thank you for the information. I think the network do matters. I have seen some limitations when you load the map without network.
However, I tested your scenario with Airplane mode on with the following code and it works.
mMapView.addLayer(new ArcGISLocalTiledLayer(Environment.getExternalStorageDirectory().getPath()+"/ArcGIS/SanFrancisco.tpk"),0);
and activity_main.xml should be:
<!-- MapView -->
    <com.esri.android.map.MapView
        android:id="@+id/map"
        android:layout_width="fill_parent"
        android:layout_height="fill_parent">
        </com.esri.android.map.MapView>
Is there anything different with your code?
